Too much fuel = studder?
Old Nov 24, 2003 | 03:08 PM
v8maro's Avatar
Default Too much fuel = studder?
Is it possible if your tune is off and you are running really rich for an LS1 to studder slightly because of too much fuel @ low rpm's?
thnx
Old Nov 24, 2003 | 03:56 PM
x phantom x's Avatar
STF veteran / 10 second club
When I installed my 36# injectors, before I got it tuned my A/F ratio was going off the charts in the rich direction. I didn't have any sort of studder or anything like that, just a noticable loss of power, and A LOT of smoke coming out of the exhaust.
Old Nov 24, 2003 | 05:43 PM
v8maro's Avatar
damn, must be the clutch :\
thanks
-Steve
Old Nov 24, 2003 | 09:36 PM
dug's Avatar
dug
A loose plug wire will cause it.
Old Nov 25, 2003 | 01:02 AM
onyxxtreme's Avatar
i ran rich for too long, and my plugs got fouled quickly
I was changing plugs every oil change, at 2.5-3k miles
I guess it was missing at low rpms, cause it "studdered" like hell
before i put the car up, i got 200 miles out of my plugs. But i was burning oil like crazy too, which really attributed to the plugs fouling up quick.
Old Nov 25, 2003 | 07:34 AM
v8maro's Avatar
thanks guys, I will check it out tonight, got an SES on the way to work, car wasnt studdering like before when i broke a spring (praying that isnt the case again) I am thinking a loose wire on #8 or some fouled plug(s) cause i know it's running rich as hell, I usually get 250-300miles/tank but I am lucky to see 200 right now. I will post an update.
-Steve
Old Nov 25, 2003 | 09:50 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Absolutely it will, and the motor will shake at idle too, because the motor is running too rich.
Old Nov 26, 2003 | 08:10 PM
onehardmaro's Avatar
I am running really rich and i have a horrible studder at idle and around 1300-1800 rpm. Im only getting 10mpg, so i dont know how bad it has to be.
Old Nov 29, 2003 | 08:14 PM
wrencher's Avatar
wrencher
It takes alot of fuel to cause a rich miss-fire but it does happen.
Old Nov 29, 2003 | 09:28 PM
red ws6 99's Avatar
You will also get a studder if the car is running lean and only slightly lean.
Gary
Old Dec 1, 2003 | 10:00 AM
BTL FED's Avatar
My motor was running VERY rich I would foul out a set of plugs in about 500 miles, and once they would foul it would studder at low rpms pretty bad
Old Dec 1, 2003 | 10:55 AM
Black02SS's Avatar
I am having the exact same problem. My plugs fouled out in about 500 miles. I also am getting about 10 mpg in town.
Old Dec 1, 2003 | 11:25 AM
I had a bad o2. My plugs never fouled out though. I think you may just need to replace your plugs. Can you tell if you have a misfire(this would diffently piont to plugs and/or wires)
Old Dec 1, 2003 | 02:40 PM
v8maro's Avatar
Turned out to be a bad O2 sensor.
-Steve
