E85 conversion
Old Sep 8, 2009 | 01:33 PM
fueltruck's Avatar
Default E85 conversion
Ive looked around a bit on the forums, couldent really find a writeup on what you need with the LS1 to go to E85, anyone got a list?
This is a stock LS1 with the exception of exaust and ram air.
My eclipse basicly required:
Fuel pump (wally 255)
Fuel Pressure Regulator (AEM)
Injectors (750cc RC)
Fuel Rail (cant remember)
Fuel Lines (braided steel)
Piggy back engine management (was on Emanage now on AEM 1930)
Dyno tune
so, what is required for the LS1 to do this conversion?
it was a night and day difference going from 93 octane to E85 in the eclipse, hoping LS1 is the same, plus in the grand sceme of things could be a cheap way to make good power and not waste money if i want to upgrade to supercharge later... id still use these mods.
Thanks for your input,
Ian
Old Sep 8, 2009 | 02:19 PM
Schwanke Engines's Avatar
LS1TECH Sponsor
Send me your computer, we'll get you some injectors, a GSS340 pump, have a nice day.
Old Sep 8, 2009 | 03:05 PM
RS_SS69's Avatar
Could you elaborate a bit more on this? What if you have 700-900hp and a turbo? What all would you need for this to be running without damage to stock rubber lines?
Old Sep 8, 2009 | 05:03 PM
millerpa's Avatar
more than likely when your up in that hp range on E85 your going to be running a sumped inline pump or multiple intake pumps. so there for all your stock lines will be steel braided and completely redone. so nothing to worry about. there's a old material they used for o-rings that deteriated with E-85 but on the newer vehicles i havnt seen any problems or heard about any. we have three small block FI cars that are on E85. 2 are over 1000rwhp, and the pro car is around 2200hp
all you need to convert to E85 is injectors, pump, and retune.
Old Sep 8, 2009 | 06:11 PM
TT632's Avatar
Dyno tune
Ian
It will be a wash if you are NA with a stock or close to stock LS1. Do a little searching here, its been done for quite a while.
Old Sep 8, 2009 | 06:35 PM
RS_SS69's Avatar
Thanks paul, that will have to wait for a bit I guess.
Old Sep 8, 2009 | 06:56 PM
WSsick's Avatar
really? did you look very hard?
https://ls1tech.com/forums/fueling-i...r-ls1-e85.html
millerpa is right, bigger injectors, pump & a retune.
to whoever asked about it damaging lines, no ti wont. ethanol is non-corrosive, common misconception. read through that link. its a VERY good read.
Old Sep 8, 2009 | 08:25 PM
MJD's Avatar
MJD
A tune is a must. Injectors are probably all you'll need but I wouldn't swap them until you find you duty cycle after converting. I'm at 442rwhp and still on stock pump with booster and 42# injectors running about 80%. I did not pick up any power with the conversion but I didn't lose any either. Getting ready to add boost to the mix.
Old Sep 8, 2009 | 08:57 PM
vaticano's Avatar
Pump injectors and a tune as has been stated. I run twin intank pumps and 79# injectors thru the stock feed lines.
Old Sep 8, 2009 | 10:27 PM
fueltruck's Avatar
Default ohh
Originally Posted by WSsick
ok, guess not, thanks
second time this happened... guess ima just stop posting questions
Thanks to those who helped, glad to hear this is easier then my ol' ricer
Old Sep 8, 2009 | 11:44 PM
Funkster's Avatar
Don't stress too much. Happens to a bunch of people.
One big help is when you enter your search info make sure you are in advanced search mode and then select sort by relevancy.
They are all right though, simple procedure just remember you need a bit more injector and pump then you would if you were running gasoline.
I am building an 416" LS3 with spray and I will be doing E85 as well. Good way to keep cost and detonation down.
Old Sep 9, 2009 | 09:54 AM
WSsick's Avatar
no sorry i didnt mean to come off like a dick. guess i should have re-read that. just trying to show you that its out there. our search isnt as helpful as it used to be, now i usually go to google and do
site:ls1tech.com and then whatever words i wanna search and it works great, like it used to lol. the search here has tricks, like using quotes and what not. dont stop posting questions, just make sure you are very thorough before you do, because in a lot of sections, there will be more than 1 thread at a time on the same thing.
Old Sep 11, 2009 | 02:26 AM
ericwilloughby's Avatar
Done it years ago on ls2. All you need is a tune. The ls2 injectors are #32 and that's enough for the stock power. And its not a wash on power. On ls1gto I posted my dyno charts oem gas vs oem e-85. Was like 15 hp 30 wtq better.
Old May 4, 2016 | 07:27 PM
power5's Avatar
My car is running Texas speed head and their mild cam. 32# injectors and 80mm tb. Long tube headers and 3" exhaist with no cats and magnaflow. Would it be worth converting to e85? Also how would I be able to go about switching from pump to e85 tune on the fly?
Old May 6, 2016 | 02:14 AM
The lines aren't rubber. There nylon. All u need is to have a way to richen the afr
Old May 6, 2016 | 02:21 AM
Actually switching your tune on the fly is asking to much of an oem ECM. It can be done with an ECM that accepts input from a fuel content sensor but all that isn't necessary.
Since you're not FI all u need to do is set afr to 12.2. If u can't do that you could raise the fuel pressure 15%
The ecm can adjust the afr up or down, from 12.2, enough to compensate for which ever fuel you are using via the oxygen sensors.
This is what I'm currently doing on my ls3
