Best bang 4 buck replacement pump
Old Sep 13, 2009 | 07:16 PM
1nastyss's Avatar
Default Best bang 4 buck replacement pump
I have a bad pump on my car, i has normal pressure when running, but drops to zero when shut off, thus resulting in having to turn the key to prime like 2 times before starting.....Anyways, i want a good, cheap replacement that will be plug and play without having to run new wires and other ****, just want to a quick and easy install.....Maybe a walbro 255, or racetronix
Old Sep 13, 2009 | 08:16 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Good & cheap often do not belong in the same sentence.
As for the Racetronix, it is a good pump & you can run it without a hot wire kit, but for the small price increase, you should buy the hotwire.
These kits also have the factory style flex hose, not the failure prone rubber stuff.
I keep them in stock as well.
Old Sep 13, 2009 | 09:34 PM
1nastyss's Avatar
Ill be calling u soon, thanks
Old Sep 19, 2009 | 12:03 PM
MIGHTYMOUSE's Avatar
its possibly your fuel pressure regulator and not the pump at all... but the factory pump does have a history of the one way getting stuck and leaking down
Old Sep 19, 2009 | 12:06 PM
streetassasin's Avatar
Im running this one
http://texas-speed.com/shop/item.asp...d=225&catid=10
Its really a Granatelli kit with a walbro pump
