Group buy 90lb ls injectors
I like this forum soo much.
Ares Galaxy Turbo Accelerator (AGTA) is probably the best
accessory-tool you can attach to your Ares Galaxy client if you are
looking for enhanced download speeds, more stability, better
connectivity and general improved downloading experience. AGTA comes
totally clean and free of charge!
I'm not sure what I need ....Im new to having a big power naturally aspirated Chevy LS built , 421CID 14 to 1 compression AFR CNC ported Heads ,sheet metal intake and a 102 MM Throttle body .
we looked an online injector calculator with the target HP of 800 and a 50% duty cycle it came back 90 LB injectors , please advise and if the info we found is correct how di I order and pay for them
thank you for your time
WE ARE OFFERING THESE ON A GROUP BUY 10 SETS ONLY.
90LB FIC FLOW MAX BOSCH INJECTORS
BRAND NEW WITH THE PROPER O RINGS
THESE FLOW 103LBS AT LS FP
COMPLETE WITH VOLTAGE OFFSETS
FOR LS2,3,7,9 $429.00 DROP IN NO ADAPTERS THESE ARE THE EV14 BOSCH
FOR LS1 ADD 80.00 FOR WIRE AND RAIL ADAPTERS.
These will work in the LQ4 also with wire adapters. Add 40.00
Also these are available in sizes from 52 to 90 lbs same price
PM TO ORDER.
HERE IS THE LINK FOR THE INFO
http://fuelinjectorconnection.com/sh...&productId=211
PM TO ORDER.
