Racetronix 57# injectors?
LS1TECH Sponsor
Originally Posted by Nasty N8
It is not the problem of the injector that would cause your motor to blow up. The slight variance in injectors is not going to cause any problems with your tune.
Nate
Nate
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Coming from a vendor that is not a very encouraging...
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
With a possible 7%+ variance in injector flow rates from the factory one could quite easily take out a cylinder or have chronic detonation problems in a number of cylinders. These variations can also cause idle and tip-in problems.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3576_1.gif)
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
I am Sure the RaceTronix Injectors Are Great. This Thread should not have stepped on RaceTronix Feet if we are going to talk about the 60lbs injectors we should start a new thread.
FYI i sold 6acres of "swapland" 2-4ft underwater . I'll Buy that land you want to sell.
LS1TECH Sponsor
![Thatfunny](https://ls1tech.com/forums/images/smilies2/thatfunny.gif)
No we do not have any cheese or swampland for sale.
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
Originally Posted by GrannySShifting
Thats silly. If we had some kinda sequential LS1 edit, would you let me pull 7% of fuel on your back two cylinders only?
I think not
I think not
FYI some factory PCM's have individual correction as well as DFI Gen 7's and FAST PCM's for this very purpose.
Silly, definitely not!
Read and learn:
http://www.delphi.com/pdf/sae/1999-01-0546.PDF
__________________
>WEB SITE<
>WEB SITE<
Im talking about Nastys response, that off balance injectors could in no way be harmful. They could defintely do something - team up the weakest injector with the rear cylinders in an LS1 and see what happens
I know there are variances cylinder to cylinder, I work on LT1/LS1 cars for a living, and definitely have seen a trend from dead cars brought to the shop, 7 and 8 always pop![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
LT1s have a cylinder balance function in the factory PCMs as well
