Fuel set up for D1SC.
So what would you guys recommend?
I'm thinking I would go with 60# injectors but what should I do for the fuel pump?
Extra details: Completely stock motor and I wont be upping the boost till I have a proper motor set up.
I would like to get a fuel set up that will work with higher hp numbers later down the road.
http://www.lonniesperformance.com/
Under these circumstances, one of my dual pump setups will ensure you have enough pump capability, while providing a true plug-n-play solution to your fuel needs. My setup will also work on near stock applications, prevent you from buying things twice.
So I'm thinking the walbro 255 and a hotwire kit. That should be enough for now right?
When would I need to upgrade the system from there? What hp?
So I spent $120 on a walbro pump and $80 on a hot wire kit... Didn't cut it. Then added a KB boost a pump $300 that didn't cut. So I already spent enough money for a dual pump set up on band aids, that still lost fuel pressure. Do it once and forget about it, learn from my mistakes
One more thing to add, boost is very addictive. When I started my build it was only going to be 8-10 #'s of boost and that was it, I have a smaller pully and a meth kit on my desk waiting to be put in this winter, should see 14-16 #'s of boost and I'm not worried about my fuel pumps one bit.
