are the l92/ ly6 injector 40#?
the ly6 marine engine 385hp uses a 40lb delphi injector rated at 40lb at 58psi.. its actually a 34lb at industry standard 43.5psi/ The only problem with that injector is it locks up at high pressure. (over 70psi)
what about these part numbers 12587269, 12580681 there off of a 09-10 ly6 and the other is off of a 6.2L l92 truck intakes any help would be grate..
