View Poll Results: Where would u want your Fuel Cell?
In Stock location. 15 Gallon
7
100.00%
In the trunk where T-tops would go. 10 Gallon
0
0%
Multiple Choice Poll. Voters: 7. You may not vote on this poll
Fuel cell opinions Please vote
First of all to the Mods, Im not selling ANYTHING! i just would like some opinions. They would be for local sale ONLY out of the speed shop I work at.
now i want to build some Fuel cells, and i want to know if it would be better to build them for stock replacement. Or for the area in the trunk, where the t-tops would go, Or do i build both? they would both be filled through the stock spout or what ever u want to call it. They would set up to use an internal pump and, or a sump for a external pump so if down the road u want to change the fuel system u can keep the same tank. Thanks for your vote.
Give me a call we have a tried and true fuel tank for the factory location with factory filler neck and custom gauge senders. I can save you the headache of building several that do not work properly or fit right for one that has been around for almost 10 years and works the way it should. I have dealer programs if you need several at once.
Nate
Nate
Nate
Nate
Chris,
