fuel line size and hooking up new fuel rails question
I just got me a new pro flo intake and rails. I need to hook fuel up to it. Not sure of the best path for me. I am open for others suggestions. This is on a tbss with a 413cid N/a motor making 520hp I was plannig on a procharger soon and i hope to be close to 700hp.
Should i run a -8 from the tank to the rails and i am not sure what kinda Y or t etc to use. I assume i need a -8 in to 2 -6 out but i don't see any adaptors like that on russell site. I found some -8 to 2-8 y but my fuel rails are 3/8npt fittings so i will have to use a -8 to 3/8npt adaptor. This will also leave me open for 2 fuel pumps.
Or should i just get a -6 adaptor at my rails and run a -6 to 2 -6 y to the fuel rails.
Thanks for the help.
I have a -8an line feeding to A -8an "T" fitting mounted on the back of my drivers side rail with a crossover to the other rail.
I used a fitting to attach my FPR onto the stock fuel lines. This solved looking for a mounting location for the FPR.
Shoot me a pm if your looking for some fitting part numbers I still have everything written down.
