2010 Camaro LS3 w/TVS 2300 – Fuel System Upgrade
I’m currently at ~ 550rwhp with a stock fuel system. Plan to upgrade the cam and do some head work then I’m done with it. After reading a number of posts about which to way the wire the KB BAP and direct discussion with KB to hold on install of 2010 Camaro/BAP combo, should I wait for the BAP install issue to be resolved or upgrade to an in-tank system such as the Fastlane solution which is pricey and an overkill for a motor that will never be north of 650?
Ya these systems are a variable already a BAP is not going to help or function correctly. We have a dual pump setup working for it. Give me a call we can see about getting you the right setup for your power.
