Effects of High Fuel Pressure
Old Dec 19, 2009 | 01:32 AM
DropTopBird's Avatar
Default Effects of High Fuel Pressure
After installing my Racetronix PnP kit, my idle pressure has been around 10psi too high. Its sitting around ~68psi. Will this have any ill effects on performance. My wideband will click over to a rich range pretty often, so I assume Im getting quite a bit more fuel than I need. Is this something that can be corrected mechanically, or is it tune related (ex possibly lowing the given injector rate to compensate for the increase of pressure?) Thanks for the help.
Old Dec 19, 2009 | 01:42 AM
speedsk899's Avatar
Sounds like you need to turn the pressure regulator down to 58PSI......hoping that you have one. At 10PSI more you are getting more fuel through the injectors then what you were tuned for.....
Old Dec 19, 2009 | 11:08 AM
Yeah Ive noticed the gas mileage go down a couple mpg since the pump install. I have all stock fuel system besides the plug and play kit (replacement pump and wiring kit). I dont think there is an adjustable fuel pressure regulator on the stock setup, am I correct?
Old May 8, 2010 | 10:38 PM
Ford_Assassin's Avatar
Bump....
Old May 8, 2010 | 10:46 PM
black98ws6ta's Avatar
No its not adjustable. The regulator is on the stock bucket assembly. Are you sure the gauge is just off?
Old May 9, 2010 | 06:19 AM
wkdivr's Avatar
Actually........................the regulator in the bucket is adjustable. You need a tamperproof screwdriver, or allen wrench. It's the same one that is on the rails on a factory return style system, but no vacum line. I would take about 1/2 to 3/4 of a turn out with it.
Old May 9, 2010 | 10:28 AM
Lonnies Performance's Avatar
LS1TECH Sponsor
You can adjust it, but before doing so, you should determine the cause.
I would tend to think something else is wrong.
A larger pump will increase the pressure up to approx 62psi at idle, but it will quickly come back down to 58 as soon as you increase the throttle opening. This is normal & reducing the pressure, will make it read too low off idle.
You situation is not normal. It should never go to 68, unless your gauge is off.... or you pinched the return hose above the tank or got something in the return line. Does your pressure come down when under load?
Also the whole mileage thing does not make sense.... increasing pressure to 68 from 58 would increase fuel flow approx 10%. The computer will easily compensate for this.
Old May 1, 2011 | 06:30 PM
01boydws6's Avatar
what would be the cause if your fuel pressure drops under load in second gear drops form 62psi to 40psi, but in 4th gear under the same load conditions pressure only drops 4-5psi?
Old May 1, 2011 | 07:12 PM
The fact that the motor is accelerating alot quicker in the lower gear. Using more fuel in a shorter period of time.
Old May 1, 2011 | 07:14 PM
LS1TECH Sponsor
Fuel starvation because the car accelerates harder in lower gears moving the fuel further toward the rear of the tank.
Also G-forces work against the fuel in the lines. The weight of the fuel tends to work against the direction of flow as the car accelerates.
Old May 1, 2011 | 07:36 PM
01boydws6's Avatar
how can I fix this problem, doesn't matter if the tank is full of fuel or almost empty If I drop the pedal in second pressure tanks to 40psi, even when the second pump which is activated via hobbs switch comes on it still doesn't help bring the fuel back up. My buddy has a similar set up as mine, he has aftermarket fuel rails and his pumps are wired together so both are on all the time, he has a crap load of fuel
Old May 1, 2011 | 07:43 PM
LS1TECH Sponsor
If I'm reading things correctly... you have 615rwhp? You are out of fuel pump. You cannot expect much over 550rwhp out of a single 255lph pump.
Give me a call if you want to discuss some pump options.
Old May 1, 2011 | 07:56 PM
01boydws6's Avatar
I haven't updated my sig. for a while, currently have twin 255's the single I bought from you right before the car went on the dyno, second is walbro gs342. The 615rwhp was with the single 255 pump and hotwire kit car was going lean above 5k so we stopped until I could get around to putting two pumps in the car. With the single pump I only saw a few psi drop on the gauge, ever since I put twin pumps in the car I have been chasing this dropping pressure issue so I have never put it back on the dyno.
Old May 1, 2011 | 09:58 PM
LS1TECH Sponsor
I would look into the way you assembled the dual pump kit... There is likely a leak somewhere internally or a problem with the way the pumps are mounted causing them to starve for fuel.
Old May 2, 2011 | 06:49 AM
01boydws6's Avatar
I originally used a t-fitting and the flex line that comes with your pump kit. since I hade to cut off the flat surface and clamp around the ribs I figured I was loosing fuel there so I got a stainless steel y fitting and used rubber line (I forget what the rating is but its rated to be submerged in the tank) the first time I put that set up the line to the second pump got pinched, I fixed that and still have the issue. The y is mounted with about a 2" pc of hose to the top of the bucket and clamped at to the bucket and to the y then the off of the legs of the y are about 3" pcs of hose that then mount to the pumps.
Old May 9, 2011 | 07:38 PM
TurboTerrorLS's Avatar
are u using a stock regulator or adjustable?
Old May 12, 2011 | 07:45 PM
01boydws6's Avatar
stock regulator
Old May 12, 2011 | 09:08 PM
LS1TECH Sponsor
Are you running both pumps continuously?
If so this is the reason for high idle pressure. Adjusting the regulator will not fix this.
Old May 13, 2011 | 06:36 AM
01boydws6's Avatar
No secondary pump runs off of a hobbs switch
Old Nov 30, 2024 | 06:01 PM
1hotroc's Avatar
I had exact issue after Installing my 255lph pump in my stock fuel pump module. Idle 70-72 psi. After dropping tank multiple times to unscrew tamper proof screw on stock regulator I was able to drop psi down to 59-60. I think I took it out 1 1/2 total turns maybe 2 turns Total MF! Absolutely nothing was bent or restricted I
firmly believe that the factory fuel psi regulator is preset for the factory fuel pump output not anything bigger .
