Walbro 355 intank pump?
Originally Posted by MIGHTYMOUSE
you may be thinking of the gss340m which is still 255lph just high pressure
speed inc sells a 420lph pump i believe... or you can run two of the walbro pumps at the same time.
Oh ok cool...How can u run two intank's without the agostino set up? Can it be done?..If so do you have a link to show how to modify the stock stuff to run two intank's? I have the agostino set up now but this is for another car..Thank's,
Carter
Originally Posted by 10secondZ
Also..can the stock regulator and fuel lines hold the dual pump set up like that?..I was just planning on running both pumps to the stock pressure line..would that be ok? Thank's,
Carter
Carter
You can get a Walbro 340 from Quarter Mile Performance>>>>. I think they have them priced @ like 130(sounds weird but I believe thats what it said-- could someone clear me up on that?)
Josh S.
Josh S.
Carter
Carter
TTT, anyone?
ramcargers has the pumps around 100bux last i bought.
the stock line cannot flow as much fuel as two walbro pumps.. the line will then be holding you back.. i've seen that the stock lines can run approximately the same amount as one walbro pump at 13 volts.. which is why i went to -8.
1osecz, i have a 98 with a steel tank.. i dont have all the mess of a 99+ tank.
