5.3 approach to fuel lines give opinion !!!!
here is what I hope will be a good set up... but since I am a newbie I need opinions I have a 5.3 engine swap into a 1984 chevy truck the engine has the single rail so what I hope to do is get a russell fitting 640850 like this
http://www.jegs.com/webapp/wcs/store...ial&Ntt=640850 get two of this one for at the fuel rail and one from the 6an braided line to the corvette filter
than get some 6an ready line run it down to the corvette filter and use another of the same adapters as above and then one of this http://www.rockauto.com/catalog/raframecatalog.php (expand pic by clicking close to price) and connect that to the russell fitting and the corvette filter....
thing is that I am a over the road driver and have not yet seen the filter so I dont know if the last fitting on the link will connect to the filter or not... any one?
its hard to have to drive 650 miles a day thinking about the swap parts
thanks in advanced just trying to get this going..
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Shiner](https://ls1tech.com/forums/images/smilies2/shiner.gif)
Couldn't get the second link to work, but the first fitting will work if you're planning on using AN fittings. If you're on a budget, you can go to a salvage yard (self serve like a Pick n Pull or something) and get fittings in 5/16 and 3/8 off of almost any late model GM car or truck, I've used them for years with no problem at all, then use fuel injection rated hose to hook them to metal fuel line with fuel injection clamps. The Walbro is a good pump, but since you are working on an '84, I would get an intank Walbro and use a fuel sending unit from an '87 Chevy truck, as it will work better and last longer, plus you won't have to come up with a place to run the return line to the tank. Hope this helps.
ls1nova, would you happen to have pictures of the fittings and fuel injection hose clamp you're refferring to? The way I'm interpretting what you're saying is to use steel lines with regular flares that you can make with a $30 flaring tool. Then take the rubber hose and slide it over the metal fuel line and clamp it down?
Slide this
![](http://www.vhaudio.com/images/hose.jpg)
over this
![](http://www.cdxetextbook.com/images/pipe_doubleflarepipe.jpg)
and tighten with this
Slide this
over this
![](http://www.gd-hdc.com/UploadFile/2008_11_13_23488_152452.jpg)
LS1TECH Sponsor
I'll agree with the above post in a limited fashion...
A double clamped hose over a flare will likely hold. I am more hesitant using it at the LS1 58# pressure than the other 43psi & lower applications.
EFI hose should support the pressure, but I recommend you only use it in limited amounts.
Never run it front to rear, only use it for the flex connections at the tank & engine... use as much hard line as possible. Also check it often as it gets hard & brittle over time. I have a few old pieces here that I removed from cars, that you can actually hear them crack if you bend them. I've seen this happen in under 2 years.
I did a TPI conversion on my own Chevy truck & a short piece on the return line connection cracked under the hood, dripping fuel on the engine.
Just be careful, it doesn't take a lot of gas to make a big fire.
