Fuel System Help?
Old Feb 6, 2010 | 02:18 PM
02SLOMARO's Avatar
Default Fuel System Help?
I am debating on running e85 and i was curious on what fuel pump to run. My mods are:
383 lsx
12.5-1 cr
ms4
pro ported heads/appx 330cfm @ .600
gmpp single plane intake
90mm upper tb elbow
90mm tb
60lb injectors?...
roller rockers
etc., etc...
i have a 255 walbro with wiring upgrade kit. just curious if this would be sufficient or do i need twins? also curious if 60lb injectors will be enough. thanks in advance for the input.
Old Feb 6, 2010 | 03:05 PM
ZL1Killa's Avatar
your single 255 pump you may be fine with...someone with more knowledge can chime in with e85.... uhhh wait; have you checked out the guy on here "Runn" he did a lot of e85 stuff and write up(s).
some 60# siemen mototron injectors should do you good I would think. Check out what Runn did....its been a while since I read his thread.
Old Feb 6, 2010 | 04:11 PM
02SLOMARO's Avatar
i did a search on it and came up with a huge write up, but is mainly filled with bs and political ****. got way off base. very old thread from '06 i believe, last post was in sep of '09. but i will search "runn". thanks killa. if anyone else has anything, feel free to chime in. thanks
Old Feb 6, 2010 | 04:14 PM
02SLOMARO's Avatar
LOL!! I just did a search on Runn, and that is the thread i was talkin about. i went through every page earlier and some of it was helpful, but most was bickering. i will check it out again.
Old Feb 8, 2010 | 09:43 AM
Lonnies Performance's Avatar
LS1TECH Sponsor
Feel free to give me a call if I can be of help.
