Can the stock pump keep up?
Old Feb 6, 2010 | 03:54 PM
nitrousjunky's Avatar
Default Can the stock pump keep up?
In an 02 Z28 with 36lb injectors at 58psi making 475-500hp is the stock pump big enough? I was asked this question the other day and didnt honestly know the answer.
Old Feb 6, 2010 | 05:28 PM
ZL1Killa's Avatar
I would say no.
I would just buy the Racetronix entire PnP 255 single pump kit, wiring harness & all.
it is worth it. direct bolt in once you drop the tank and it is a damn easy install & wire in.
Old Feb 6, 2010 | 06:07 PM
1nasty86's Avatar
Turd Gen Guy
a walbro 255 pump is about a hundred bucks.
Old Feb 6, 2010 | 06:59 PM
boosted4life's Avatar
i wouldnt depend on it.
Old Feb 6, 2010 | 07:20 PM
Thats what I thought as well. Every time I have installed bigger injectors I have at the same time installed a 255 pump. I have never attempted to use the stock pump with larger injectors. Its my neighbors car and for some reason he balked at the idea of dropping the tank to install a bigger pump.
Old Feb 6, 2010 | 10:23 PM
THENASCAR's Avatar
ive seen cars do it, but also your going to be straining the pump. like these guys said, 100 dollar pump and ur set.
Old Feb 9, 2010 | 10:44 PM
NVR_SPDS's Avatar
Can it be done? Im sure it can. Is it safe? Probably not. And do you really want to take the chance on something so absolutley important? I just look at it this way: a hotwire kit, and pump is a WHOLE lot cheaper than fixing the damage done from the stock pump failing to keep up!
Old Feb 11, 2010 | 01:19 AM
InsaneDomestics's Avatar
^^^ +1 to that
