104 octane 50/50 with 93
Old Dec 24, 2003 | 04:59 PM
ssdungeon's Avatar
Default 104 octane 50/50 with 93
Any gains to this all the old school guys use this here. I also need to know if this will be safe for my O2s and plugs. Any advanced programming needed.
TR55s,
Thanks,
Old Dec 24, 2003 | 06:22 PM
Sudz's Avatar
I read that the pcm doesnt read anything higher than 94 octane? so youd prolly be wasting your cash, im not real sure, someone here will know~
Old Dec 24, 2003 | 09:26 PM
Cummins's Avatar
i agree with Sudz, pcm doesnt register anything over 94 octane, ive heard that running a higher octane then 94 can actually cause you to lose performance.
Old Dec 24, 2003 | 09:32 PM
whitt1's Avatar
The fuel mix you are discribing runs great in my supercharged truck.The PCM checks for knock not octane.If you have a problem with knock due to low octane fuel,then mixing 104 octane racing fuel will help your performance a lot.Engines perform best on the lowest octane fuel that doesn't produce knock.If the 93 octane is not producing knock,the additional expense would be wasted.
Old Dec 25, 2003 | 02:23 AM
ssdungeon's Avatar
Well no knock at 31.0 degrees timing so I will leave it be. Thanks for the info...
Old Dec 25, 2003 | 09:18 AM
sawedoff's Avatar
With those mixtures in those amounts, it would be around a high 97-98 octane fuel.
