Are 30lb. injectors to big for a stock motor?
I am wondering are 30 lb. injectors to big for a stock motor. I am curious because I just bought a walbro 340 intake fuel pump (stock pump going bad), I am in the process of buying an adjustabel fuel pressure regulator (stock regulator going bad), and I was wondering if the 30lb. injectors are just to big. I would put 28lb injectors on it but I have not been able to find them yet. Just for the info I am redoing the fuel system because the car has 153,000 miles on it, and it will be tuned after the parts are installed. Any help woulb be very appreciative.
Thanks,
Chris
1998 Silver Trans Am
Best e.t. 13.2@106
Mods: 3000 stall (new), 3.73 gears, direct flow lid, ported maf, flowmaster exhaust, HPPIII, Free ram air mod, and Ram air hood and air box.
Thanks,
Chris
Best e.t. 13.2@106
98 are 28 but at more than the industry standard of 3.0bar fpr rating.
So if you put 30# in you might need to get a lower fpr for good idle/etc. They look a helluva lot like the vw mk3/mk4 fpr's which are quite abundant.
