Walbro 255 problems.
Old Apr 15, 2010 | 05:01 PM
custm2500's Avatar
Ph.D. in HUBRIS
Don't have an intank pump. Pump is bad. Only builds 50 psi with the return line pinched off.
Sending it back to summit to get it replaced.
Old Apr 16, 2010 | 05:36 PM
custm2500's Avatar
Ph.D. in HUBRIS
I wanted to verify the pump was bad so I used the pump to drain the tank. It had the just the 12 inch long -8 hose from the tank and 3 feet of 3/8ths hose and was barly trickling out of the hose. Obviously not nearly what it should be pumping out and the whole reason why I had all these problems.
I did verify that I had a full 12+ volts and I did.
Old May 18, 2010 | 05:40 PM
custm2500's Avatar
Ph.D. in HUBRIS
Finally got the truck back together with a new pump. Not one single issue. Pump is silent, so quiet in fact I didn't know it was working. I thought I had the pressure gage hooked up and it showed no pressure, but the truck started and shut off, started it up again and it stayed running. Then I actually hooked up the pressure gage and running just over 60 psi.
I am so happy!
Old May 18, 2010 | 08:14 PM
Mac 2002 SS's Avatar
Man ,I'm happy you got your fuel pump straight. I'm planning on getting an in-line fuel pump for my SS when I upgrade my injectors in the future. You had me a little worried about going with an in-line pump at first ,but now I see you just had a bad one to begin with. I'm glad Summit did you right man .
Old May 19, 2010 | 06:22 PM
custm2500's Avatar
Ph.D. in HUBRIS
I am very happy too! The first one was so loud but I figured they just were since in line pumps sometimes are fairly loud. The new one doesn't make a sound. I am so happy.
