6.0,LS3 heads , what injectors ??? HELP
I have a 6.0 ,with lightly ported LS3 heads,a big cam,,LS3 intakeheaders,3600 stall,3,700lb car guessing on that,full weight 70 chevelle,i just purchased the LS3 complete intake with injectors 39-40lb injectors,if i use those im gonna have to buy the wiring harness adapters cause i have 99 TA motor harness,can i make those work,thats the cheapest route ? I can also turn my fuel pressure up to whatever i have a aeromotive eliminator pump.What do you guys think ???
Im using an LS1 crank,reread my thread.Im wanting to know what lb injector i will need for this kind of power setupsetup ,can i get by with a 39-40 lb injector ?????????
They should be fine for your app. The stock injectors and fuel rail will support over 500 hp. You will need the wiring adaptors FAST #170604-8. Casper Elec. and some other companies make them also. Using these and the stock rail and injectors is by far the cheapest way to go. I just spent 275.00 on AN fittings and hose for my build. Add 180.00 for the rail, plus 380.00 for the injectors the cost goes up and up. I went with the Fast 57 lbs fwiw. Dual 6 an feeds into the rear of the rails and dual 4an out the front for N2O fuel.
Just run them at 58-60 psi. Thats how GM rates them.
