Factory LS6 injector size ??
Is it the same as the ls1 injector? The reason I ask is I ordered a crate ls6 motor(04-05 cts-v) and want to know if I can use my stock 04 gto injectors . I already had my 01 injectors resized to 36lb at 3 bar(by you) but am leaving the ls6 stock besides for headers. I know the resized injectors are too large. What size injectors do you reccomend? Or will the stock size 04 gto ls1 injectors be fine? I think the stock ls1 and ls6 may be the same size.Can you confirm? Thanks
