how is the fuel pump controled?
Old Mar 15, 2010 | 12:20 PM
bad6as's Avatar
Default how is the fuel pump controled?
im doing a ls1 swap in my mustang, i have a stand alone harness. i ermember in my camaro i turn the key to on and the fuel pump turned on for a few secconds then turned off.
now when i turn on my key it just keeps running.
Old Mar 15, 2010 | 12:55 PM
lvbroham1's Avatar
I'm pretty sure the pump primes when the key is in the on position, yes then it's on. Is the fuel pump continually priming when in the on position?
Old Mar 15, 2010 | 01:00 PM
bad6as's Avatar
yes pump keeps running
Old Mar 15, 2010 | 07:22 PM
bad6as's Avatar
nevermind. hooked it all back up. when key is turned on the pump runs for 2 sec. its controled by the computer
Old Mar 16, 2010 | 07:53 AM
make-believe's Avatar
A fuel pump for a direct injection internal combustion engine having a body with a valve seat. The valve includes a valve head and the valve is movably mounted to the body between an open position and a closed position. In its open position, the valve head is spaced from the valve seat white in its closed position, the valve head abuts against the valve seat and closes the valve. An electric coil upon energization moves the valve to an open position and, conversely, upon deenergization allows the valve to move to a closed position. A control circuit controls the energization of the coil to reduce the pump noise during operation of the engine, especially at low speeds.
