2002 Intank fuel pump recomendations
If I can not find it I will put something together again shortly when I have some spare time. It has been unusually busy here since the new year.
Please hurry some of need a solution in the next 4-5 months.
Chad
Did I misunderstand? I thought when Racetronix posted the following it was for 02 specific cars:
Because it requires a special type of pump that will work in combination with the fuel module's venturi system which keeps the pump immersed in fuel regardless of the level of fuel in the tank.
Everyone that is installing a standard Walbro pump is doing away with this function by punching a hole in the bottom of their fuel module so that the pump has a supply of fuel.
Is this just the 02 cars or was he talking about all 99-02 F-bodies?
Chad
Chad
The current Racetronix system only works in the F-LS1 cars equipped with a metal gas tank.
The F-LS1 cars equipped with plastic tanks all have fuel module which uses the venturi fill system which only functions with the factory pump assembly.
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Why would GM change fuel modules in a C5 half way through a production season?
This is not so uncommon but generally these deviations are with less visually obvious items. That is why it is always best to supply a VIN when buying parts for your car as oppose to just the make and model year.
>WEB SITE<
https://ls1tech.com/forums/fueling-injection/72211-racetronix-99-up-f-body-pump-coming-very-soon.html
https://ls1tech.com/forums/fueling-injection/91352-whats-going-racetronix-intank-us-99-up-guys.html
-Ken
An inline pump will still be limited from the restriction on the stock pump.
-Ken
A inline pump will not do you any good itcan`t pull more fuel through the pump in the tank than that pump is capable of pumping.
Nate
Works great so far. (2K Miles)
