fuel pump question
Old Apr 18, 2010 | 02:03 PM
Pate_2008's Avatar
Default fuel pump question
I have a few questions. I know that this pump is a direct fitment into my car because of other guys around here run this pump.. http://www.racetronix.com/RX-F98-FPKG-2.html
But this pump is what i am leaning towards and want to know if it is a direct fitment or what needs to be changed on it if its just the plug in or what if thats the only thing then i just need to splice it no biggy let me know thanks
http://www.jegs.com/i/Granatelli/467/GM722-2/10002/-1
Old Apr 18, 2010 | 06:34 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
The jegs kit is very generic, as there was 4 different pumps used between '82 & '02. That is not correct for any of them.
Also a good kit will not use a rubber connection hose.
Get the correct one (Racetronix) & save yourself some problems.
Old Apr 18, 2010 | 06:48 PM
Pate_2008's Avatar
Ok i didn't know what would have to be altered. The stock pump has a rubber connection hose btw.
Old Apr 19, 2010 | 02:58 PM
LS1TECH Sponsor
A 98 does not have a rubber supply line, unless the pump was already changed....
Old Apr 19, 2010 | 05:53 PM
Pate_2008's Avatar
well humm... it looks just like what the 255's are in the pictures with the little rubber hose that connects to the top then has zip ties with the rubber hose to hold it off the metal.
Old Apr 19, 2010 | 05:59 PM
Pate_2008's Avatar
mine has the float arm, but then has a pump like a 255 with the rubber hose. Then off the return line it has a plastic hose going into a filter as well.
Old Apr 19, 2010 | 06:30 PM
Pate_2008's Avatar
ok so just confermed that it is a walbro gss340m that is on it now which is a 255 pump and we were comanding 10.5 afr and was still going 17afr lean when you got into it.
Old Apr 19, 2010 | 07:20 PM
LS1TECH Sponsor
Fuel pressure is the only way to determine flow capacity. If it holds pressure under full throttle, the pump has enough capacity.
When fuel pressure drops significantly (more than approx 3-5psi), there is not enough capacity. Typically it will fall dastically when you run out of pump.
