Need to know the flow rate of ls3 injectors?
Old May 4, 2010 | 07:39 PM
bigfatls6's Avatar
Default Need to know the flow rate of ls3 injectors?
Im going to be doing a ls3 heads and intake combo and need to know the injector flow rate for stock ls3 injectors. I need the info for the tune. I have done a search and only thing I figured out is they are different from the l92's flow rate.
Old May 5, 2010 | 09:30 PM
FICINJECTORS's Avatar
the part number should be 0280156051 the LS3 injector at 58psi is a 42
Old May 5, 2010 | 10:03 PM
bigfatls6's Avatar
Thanks for the help what are they rated at with fuel pressure at 43.5? Also these are ls3 injectors not the l92 injectors.
Old May 6, 2010 | 05:34 AM
l92 injectors are Delphi, ls3 car are Bosch if they are the pn I gave you in the last post they are 36@3bar
By Brett Foote | 2026-06-04 05:00:17
