injector size for 408?
Old May 13, 2010 | 08:17 AM
00 black ss's Avatar
Default injector size for 408?
im building a 408 mods are 1 7/8 lts, asp underdrive pulley, tea stage 2 317's, ls6 intake,, and a pretty big cam. what size injectors would i need to support this? also could i get by on the stock fuel pump?
Old May 13, 2010 | 10:05 AM
Nasty N8's Avatar
42# inj and no the stock pump is not enough you will need a direct replacement Racetronix pump.
Old May 13, 2010 | 12:54 PM
would i just need the pump or would i need the hot wire kit also?
Old May 13, 2010 | 07:43 PM
SSPerformance's Avatar
do the hot wire kit
Old May 13, 2010 | 07:49 PM
Nasty N8's Avatar
The Hotwire kit supplies the new pump with adequate voltage that the stock wiring is way to small for.
