injector in a 5th gen?
Old May 23, 2010 | 03:11 PM
grimmick's Avatar
Default injector in a 5th gen?
ok i got a 6.2l ls3 in the 10 camaro and i was wonderin if the fuel injectors were a weak link in building power or if they can handle a lot of demand and if anybody knows the specs on the stock injectors that would be awsome too
Old May 23, 2010 | 06:46 PM
FICINJECTORS's Avatar
the stock injector is Bosch Pn 0280158051 it is 42lbs at 58psi.. We have drop in replacements that are 52lbs at 43.5 or 60 in your rail.. They would handle most of your needs, If you need even bigger we have them to a 103lbs
