Fuel Pump Question
Old May 21, 2010 | 12:59 PM
flatbird's Avatar
Default Fuel Pump Question
I am wanting to replace my stock fuel pump. I dont really need a racetronix for my setup, so is there any pump only replacements, without the sending unit, that I can buy? Thanks...
Old May 21, 2010 | 01:11 PM
72 Z-28's Avatar
My pump on my 98 went out and I put a walboro 255 in it. It seemed to be a very good pump. Whatever you do don't get a non-name brand just to save 30-40 bucks I did that the first time and it lasted like 2weeks and I had to do it all over again. Hope this helps GL
Old May 21, 2010 | 01:35 PM
flatbird's Avatar
Im concerned that the 255 lph will be to much for my setup. I only have headers, and an aftermarket ls1 lid. Also, you think if i did use the walbro it would effect my gas milage?
Old May 21, 2010 | 03:01 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
The Racetronix kit does not include the sender... only the pump, wiring & sock.
I have these in stock if interested. I also have stock replacements with sender as well.
Feel free to give me a call.
Old May 21, 2010 | 03:09 PM
flatbird's Avatar
Thanks Lonnie. I'll give you a call when I've narrowed my options and am closer to a purchase date.
Old May 21, 2010 | 03:40 PM
disc0monkey's Avatar
did your old one burn out? i wouldnt touch it unless your experiencing problems.
Old May 21, 2010 | 03:48 PM
flatbird's Avatar
I just would rather change it voluntarily than have it go out on me at an inopportune time.
Old May 21, 2010 | 03:49 PM
flatbird's Avatar
Would that be a mistake?
Old May 23, 2010 | 08:38 AM
yeah IMO its not worth doing just for the risk of it failing. i mean you can open a can of worms for nothing.
Old May 23, 2010 | 05:53 PM
koolaid_kid's Avatar
Your fuel pressure regulator takes care of this, the excess capacity is not an issue, and fuel economy will not change with only a change in pump.
AFA when to change it, you can always wait until it strands you 50 miles from home. Your call.
Old May 23, 2010 | 10:06 PM
99T/AMAN's Avatar
I wasnt having any problems with mine but i changed the pump and put in the harness also. I am installing a cam and stock 243's and just didnt want it starving the motor. I wouldnt worry about it unless you are planning more stuff to do.
