Need Stock Wiring Diagram
Did a lot searching and only thing coming back is for Racetronix. Having to re-wire my car's fuel system back to stock and have no idea whats still stock and whats been chopped. Thanks.
Theres not much to the Factory Fuel System. Here is a diagram of the Factory system. It has the Relay under the hood that gets power through the underhood fuse panel "20 amp Fuel Pump Fuse" and one side of the coil gets ground and the other get 12v trigger from the PCM Dk Green/White wire pin 9. Your gray output wire goes directly to the fuel pump. Hope this is what you were looking for.
