Injector duty question..
What injectors do you have? I've seen a heads/cam car that was hitting 100% around 4700 on stock 28s drop to around mid 50% max with some green top fords.
The green tops are around 52 at 58psi and the reds are 36. If you're keeping your desired AFR inline than you should be alright for now on the reds but if you move up I would at least go with the greens. Neither of these injector are considered too big. You have to think that Ford runs the greens on a smaller motor which would need less fuel at idle and part throttle than an LS1.
Plus the fact that the FORD injectors have all the data readily available for tuning makes them an easy choice for me.
If you are actually going lean on the dyno (not just from bad tuning) then I would look at the pump first. I've seen injectors go to 120% by the PCM and still keep up with my commanded AFR.
36lbs/hr injectors should be able to run 450rwhp all day long, if they are in good working order.
You even stated " should work if the injectors is in good working order " That is the point of staying @ or below 80%. I am not an injectors expert but you are misleading anyone reading this post by saying 120% injector can keep up with your desired AFR- Safely.
The safety margin is there for safety. As with everything you can run it over the margin and you may not ever have trouble. You are would be over working.
And I said that red tops should be enough for 450 rwhp and a safety margin. Of course, every car and setup is different, but he should check the pump. If it's not pumping enough then the injector will have stay open longer for the same amount of fuel or it will just go lean.
the % data is a calculated guess of the injector flow rate table-been caught out to many times thinking i need a bigger injector....
if really unsure log the afr to see if you have control vs your fuel pressure- vs your commanded
