Billet rail adapter help
I bought a set of billet rails set up for a LS2. The problem is I have a LS1
I need the adapter blocks and cant seem to locate a set. What makes matters more tricky is there is no name on the rails and I cant ID them to contact the company
Ive found several companies selling LS1 to LS2 conversion kits with the injector spacers and rail mount offset adapters, but none selling replacement blocks
Black pieces in the pic
![](http://i150.photobucket.com/albums/s98/Pocket_004/ls1/DSC01875.jpg)
Thanks for the info
I made a set of hold downs, it wasnt too difficult
Next question, do LS2 injectors use a different OD upper O-ring? The LS1 injectors slid into the holes rather easily compared to the stock rail and leaked when I primed the fuel system. I can take some caliper measures of the holes if it'd help
