Whos running 2 Walbros all the time?
It's hard to say whether your external walbro with an intank will suffice. All of the flow data for walbros are based upon suction feed. When you pressurize the inlet it will increase the flow.
Lots of us run dual externals. I run dual external bosch 044's with an in tank walbro feeding them
i run twin walboros, both external off my sumped tank, no issues, unless you count the fact one is starting to get very loud, i called walboro and they claim getting loud is not a sign of anything wrong, but i have to wonder why it was quiet for 4-5k miles and then got loud.
I think the main reason for death on a fuel pump is fuel line restriction, I run -8 line with mine just because it didnt seem right to run through such a small line,, plus it probably makes the fuel cooler.. im running 4x 255 inlines on my camaro to -10 line .. lol
Line size is not the problem, but the power required (heat generated) to run 2 pumps, plus the heat pulled from the rails/engine compartment & returned to the tank is the problem.
Excess pump capacity when not needed is just adding to the heat load on the system.
Lonnie any bad side effects from the warmer fuel? Obviously higher IAT's but is there a fix like a fuel/trans cooler sort of thing.
#33
I run twin in tank walbros all the time. I have -8 line from the tank to the rail, with a "T" in the line and back into the factory LS1 style in-tank reg. As other's have said, my pressure is a bit high, and usually stays around 70 PSI. I plan to remedy this by removing the in-tank reg and putting an aftermarket return-less style up by the rail. That way I'll have a full -8 return line to dump all the excess fuel back into the tank. Should be MUCH less of a restriction than the crap factory reg.
#34
would a 3/8 hardline be ok for return duty? (= 6an hose +/-)
i have my aeromotive FPR hooked to the fuel rail and then returned back to the tank via its own dedicated return line. i am thinking though to reduce some of the heat transfer to the hard line to put a short an hose between the FPR and the hardline.
not planning on that much hp, id like to be about 650ish with the extra pump. i already have a racetronics pump, and might get another, but im also holding out to see if racetronix comes out soon with a larger single pump in the 400 range. they have a pump but waiting to see if they make it drop in compatible.
