Fuel Pump Issue
Old Jun 16, 2010 | 07:24 PM
am_muscl's Avatar
Default Fuel Pump Issue
So I just replaced what I thought was a bad fuel pump with a new stock replacement.
I plugged everything in and before I bolted it down I wanted to make sure that I could at least hear it prime....I got nothing.
I checked all the fuses and all the fuses are good and I check the connectors going back to the fuel pump and it IS getting power.
I'm not sure what else could be wrong and if I don't get it fixed and driveable by July 1st the car is going to be towed away.
PLEASE HELP!!
Old Jun 16, 2010 | 09:32 PM
jdhedman's Avatar
when this gets power it will prime- just for test purpose
http://shbox.com/1/fuel_pump_prime.jpg
check this relay
http://shbox.com/1/fuel_pump_relay.jpg
and make sure you have power and ground at the pump, you may have to bolt the pump in for ground iirc
Old Jun 16, 2010 | 09:37 PM
am_muscl's Avatar
so how do you check for ground AND power. I'm pretty sure it got power because I got a reading when I got it. But I'm not sure how to check for the ground.
I'll have to check the relay and the prime connector tomorrow when I get a chance to go home.
Old Jun 16, 2010 | 09:48 PM
jdhedman's Avatar
How to use a multimeter
