stock injectors?
Old Jun 28, 2010 | 01:12 AM
sunset_Z28/RS's Avatar
Question stock injectors?
I want to know if my stock injectors will be fine for the mods in my sig + ls6 intake and ms4 cam. I not going to do any more power adder mods. No nitrous etc. etc. Im just wanting a good looking Bad *** sounding car. I have seen a few people say they are running the ms4 w/ stock injectors and said they are maxed but will it hurt anything being maxed out. I rarely ever race just drive back and forth to work and give it hell every once in a while plus i go to car shows.
Old Jun 28, 2010 | 06:54 AM
bww3588's Avatar
if you had a 98, you might get away with it, but your going to need some larger injectors.
on my 98, i had the stock 28.5#, with heads, LS6 intake, full bolt ons and an MS4, i was running 95% duty cycle, which is bad. you want to keep your duty cycle below 85%
Old Jun 28, 2010 | 11:57 AM
what is bad about running over 85%
Old Jun 28, 2010 | 12:19 PM
bww3588's Avatar
you have to remember the injector is a solenoid, over 85% and the injector will start to overheat and not work properly over time. ive seen people run theri injectors over 100% for a little bit, but that was in a pinch sitiuation, and soon fixed with proper injectors.
Old Jun 28, 2010 | 02:47 PM
SShawn's Avatar
yea, you should definitely upgrade to a 36 or 42 Bww is correct, you do not want to be running over 85%. If you are interested we do stock the 42# and can ship same day.
