Over 100psi at the rail
1999 Camaro orignally a V6
Stock V6 fuel tank
Stock V6 fuel lines
LS1 fuel bucket
Walbro GSS-341 Pump
Stock LS1 fuel rails
Racetronix 38lb/hr injectors
I thought the LS1's were regulated at the bucket? If not, where do I need to regulate? I'm under the impression that I can't use the Vette filter/regulator assembly, since my system is returnless.
You can install a returnless regulator, it will work just fine. You can go either way tho
- Fuel regulator
- Fittings
- Fuel hose
- Hose clamps
- Teflon paste or loctite thread sealant (Some regulators have O-ring fittings, so they don't need any sealant)
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Instant filtered and regulated 58 psi.
www.speartech.com
Where's it go??
Your plan won't work too well if the return line just spews out under the car somewhere!
www.speartech.com
www.speartech.com
