reg problem or pump??
Old Jul 6, 2010 | 11:47 AM
ls1racer1999's Avatar
Default reg problem or pump??
hey guys i can drive my car for days and no problems but then out of know where fuel pressure will drop from 60 psi then drop to about 20 psi and spit and sputter it has a walboro 255 in there that i installed 2 years ago .i took it out cleaned the screen and put it back in about 2 months ago and ran great then just yesterday i was on a cruise for about 5 hr and it as about 90 deg out drove fine then i heard a pop and looked at gauge and saw it dropping to 40,20,60 then would stay at 20 so i puled over and took pump out and checked screen it as clear. when u turn key on to prime u can here the pump but it sounds like its trying to run against high pressure . and when i pulled off the lines gas shot out bolth lines like it as under high pressure filter hasn't been changed in awhile should i try that first??
Old Jul 6, 2010 | 04:08 PM
Nasty N8's Avatar
Always try a filter first. Do you have the hotwire on the pump? Is the connector at the top of the tank OK?
Old Jul 6, 2010 | 08:27 PM
hey it was the filter im going to buy a hot wire kit shortly but thank you for the suggestions
