fuel pressure is 48psi after pump primes
The fuel pressure is at 60 when the pump primes then it drops down to 48. Should it stay around 60psi?
My regulator is a 99 vette regulator/filter. And the fuel pump is internal It came with the spectra tank I bought.
when I turn my key on and it primes, it goes to 55 and drops to 50. when I start it, idling it runs right at 60-62. If your staying around 60 or so when running I wouldn't worry about, if you drop when you just turn the key on it's prob. fine. As long as it's not that low running.
