Problem in stock Fuel Pumps
Old Jan 22, 2004 | 05:54 AM
LS1SS4ever's Avatar
Question Problem in stock Fuel Pumps
Stock Fuel Pumps 4 times had changed so what is the solution it isn’t in my car it is in my friend? His car model 97 Z28
Old Jan 23, 2004 | 03:06 AM
soundmaster's Avatar
Mine went out twice already within the same week. I had an issue when I took my supercharger off. It's probably not the fuel pump - take it to the dealer to check the circuits and wiring... something else could be causing the fuel pump to malfunction. Just to be safe you might want to change the fuel filter while you're at it.
Old Jan 23, 2004 | 10:08 AM
slow's Avatar
how long of a period of time?
does he fill it at 1/4 tank, like you should, or does he overheat the pump, and run it to almost dry everytime?
Ryan.
