Can the Racetronix hotwire kit be installed through a trap door?
![](https://i246.photobucket.com/albums/gg92/TommyLS1/car/trapdoor.jpg)
Will this much access to the top of the tank be enough, or will the tank have to be dropped? It looks like when I pop off that sheetmetal rectangle I'll be able to get to the pump but maybe not much else.
Well I'm in the middle of it now and my fears have been confirmed. I had to run the harness up through a grommet hole in the trunk on the driver side, along the top of the sheetmetal and down into the back of the pump, as opposed to along the tank itself (which is apparently only possible with the tank dropped away from the car). It ain't pretty but hopefully it'll work.
I just did this 2 months ago. I did it through the trap door. I took the wiring harness of the hotwire kit, taped it up to the end of a coat hanger, bent it a little and pushed it up and through from under the car where the fuel lines go up top of the fuel tank. Took 5 minutes. When you get it up, move around to the top, pull the rest through, un tape it and plug in the connections. Then run the rest of the wiring along the brake lines to the engine bay, self tap the fuse in a clean location and connect to the alternator. It took me about a hour all said and done.
It looked to me like there just wasn't enough clearance between the tank and the car to get the harness plugs through; I even tested it by trying to snake a length of heater hose (which was not quite as big around as the plugs) along the tank to the underside of the car and it wouldn't go through. Guess I was somehow doing it wrong. But since it's already in there then screw it, as long as it works then I'm not climbing underneath that bitch again just to try to tidy it up. It's hot as ***** outside and in my garage.
Where were you guys when I started this thread on Wednesday?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
