aviation fuel
JP5 & JP8 are kerosene derivitives used in diesel aircraft & jet engines.
100LL is gasoline used in gasoline aircraft engines. It is a dry non-oily fuel so as not to leave deposits in mechanical fuel injection on these aircraft.
It does not burn hotter. In fact air cooled aircraft engines are more sensitive to cylinder heat than water cooled engines, so this is closely monitored & controlled.
It does not have road taxes on it, so use is punishible by strict fines.
It does work well in cars, but will ruin cats & o2 sensors.
Long term effect on injectors is not known, but I would suspect it will not hurt them for a very long time.
It run it straight & it works well in my 12:1 Camaro & also my 2 stroke quad.
Currently it is under $5 per gallon so compared to race fuel it is a good price.
