Injector Interchange?
Old Aug 24, 2010 | 08:28 PM
jaymcjay's Avatar
Default Injector Interchange?
Ok, so here's my ultra-noob question...
I've sucessfully transplanted an LM7 in my jeep.
I'm moving the motor over to a buggy chassis, and for hood / radiator clearance I'm planning on running the intake backwards.
I picked up an LS1 intake and fuel rail from a buddy. It all seems to be A-OK to plop it on backwards, but when I went to put the injectors in the intake they didn't seem to fit. They bottomed out before they reached a good sealing location. The tops also didn't fit too well into the steel fuel rails.
So...have I opened a can of worms? What do I need to do/get to make the lower intake work out for me?
I've already re-routed the wires in the harness to reach the DBW throttle body, so I thought I was (almost) free and clear!
Thanks!
Old Aug 25, 2010 | 02:14 PM
incbed's Avatar
Sounds like you have an LS2 intake. The LS2 intakes have larger injector nozzle holes than the LS1 intake. Does the intake manifold you have,,,have 3 mounting bolt holes for the throttle body or 4 bolts holes to mount the throttle body??
Old Aug 25, 2010 | 02:32 PM
jaymcjay's Avatar
Both intakes have 3 bolts to hold the throttle body on.
That part worked out just as planned...
Old Aug 25, 2010 | 03:09 PM
incbed's Avatar
hmm then you don't have the LS2 intake.
You might need to buy new orings for your injectors.They are really cheap.
Old Aug 25, 2010 | 03:12 PM
jaymcjay's Avatar
Are all Chevy injectors the same body size?
I'll take some measurements tonight and post them. Seems like there must be something stupid I'm missing.
Old Aug 25, 2010 | 03:21 PM
incbed's Avatar
all the LS1 engines share the same size injectors.
The LS2's are different than the LS1 injectors.
I'm not sure about the Truck injectors though.
If this helps I just changed my injectors on my LS1 and the old ones were hard to get out of the intake and fuel rail and the new ones were hard to push into the intake and fuel rail.
I would also like to see a pick of your Jeep Transplant.
I had a 1979 CJ7 with a 350 TBI turbo350 Np205 transfercase with 14bolt rear and Dana60 front with 39.5 boggers then they closed down Tellico and I sold it.Sad part is I only got to wheel in it only twice.
Old Sep 4, 2010 | 04:54 AM
fabron's Avatar
the vortec injectors are truck only delphi injectors. they are smaller than ls injectors and the plugs are different.
Old Sep 6, 2010 | 08:23 PM
jaymcjay's Avatar
Not what I wanted to hear, but thanks for the info none the less!
I guess I'll probably just stick with my truck intake for now. The hood clearance isn't what I was hoping for...but I'll survive.
