Bosch 044 help?
Old Aug 28, 2010 | 02:18 PM
Marcello7x's Avatar
Default Bosch 044 help?
Does this top fitting with the pump have to be used? I have a male fitting for the inlet that adapts to my filter that i would like to use. I also don't know what that fitting with holes in it is for. It seems to have springs inside.
Any help would be great!
Old Aug 29, 2010 | 11:24 AM
MGMC's Avatar
thats the one way check valve, im not using mine either. if u dont use it then you wont have any pressure when the car is off. no biggie
Old Aug 29, 2010 | 07:05 PM
Marcello7x's Avatar
ok thanks man!
Old Sep 1, 2010 | 09:25 AM
2XR95Z28's Avatar
I'm not using mine either. I just turn the key to prime the pump once or twice before i fire it and have had no problems so far.
