fuel pump ?
Old Sep 1, 2010 | 09:09 AM
Chris'stransam's Avatar
Default fuel pump ?
OK , I was driving home Monday from work ,and had the car in 5th gear running about 60mph and went to hit the gas and it started to sputter real bad. I got the car home and it died in the driveway. The TA would start but not rev it would spit and sputter. Now started it up to day , and it wont run unless u have your foot on the gas and rev like normal. When u take your foot off it spit and sputters . NOw this is the exect opposite of the day before WTF. I had order a racetronix pump and the wire harness . WILL THIS FIX IT ?
Old Sep 1, 2010 | 12:23 PM
SOMbitch's Avatar
We can't answer that until you check your current fuel pressure. Get a guage and tap into the schrader valve on the DS fuel rail. Should be 58psi....
Old Sep 1, 2010 | 01:06 PM
what size is the schrader valve
Old Sep 1, 2010 | 01:07 PM
SShawn's Avatar
could be a number of things. What he mentioned is a good starting point to see if it is indeed your pump. Have you made any recent changes to your car?
Old Sep 1, 2010 | 01:27 PM
no ! I changed the plugs out about 2month ago from tr6 to a tr5 . I am goning to put the denso back in that I pulled out when I did nitrous ,and see if it helps, and unplug the mas air meter and check the psi in rail
Old Sep 1, 2010 | 06:02 PM
Car boggs under load.
Old Sep 6, 2010 | 11:14 PM
tricked94camaro's Avatar
lol!
