part numbers for USCAR injector harness components
I'm going to be running injectors with USCAR connectors on them on my new LS1 setup in my Caprice, and the harness I'm using to START the conversion wiring is from a 2000 Z28...so it's got the wrong style injector plugs on it.
I don't want to run conversion plugs, I think they look cheesy, and I don't want to solder pigtails in either, I have all the right style crimping tools to re-pin harnesses, I am just trying to find the part numbers for the connector body, seal, and pins...and if there's any other components to the connectors.
If you know what they are, please post them, if not, I'll post them when I find them.
Thank you for the offer...but I never like to buy connectors with exactly enough...I prefer surplus and options...and some of the parts are common to other Delphi GT connectors used under the hood.
Pretty sure I found all the Delphi GT MFG part numbers:
Connector body is 15419715 (includes internals, lock lever and seal)...this is grey, there's a black version too, but not stocked
Pins are 12191819 (for 1.00 - 0.75mm diameter wire with 2.25 - 1.70mm insulation, use 12191818 for 0.50 - 0.35mm wire with 1.85 - 1.20mm insulation)
White wire seals (for 1.2 - 1.9 mm wire) are 15366021
Blue wire seals (for 1.86 - 2.4 mm wire) are 15366060
TPA is 15423278 (terminal position assurance...this is the plastic part that goes on top of the connector to keep the wires in line)
CPA is 15423276 (connector position assurance...this is the plastic part that inserts into the connector after it's plugged into the injector to keep it locked)
Just ordered 10 connectors, 10 TPA's, 10 CPA's, 20 of each size pin, and 20 of each size wire seal (planning to use the larger diameter, but still...the pins are $0.15 each and the seals are $0.04 for one size and $0.09 for the other...meh, might as well have them)...grand total including shipping (priority mail with delivery confirmation) is $28.05...plus the research taught me more about Delphi's GT series...which I previously knew a LOT less about...knew quite a bit about Metripack and Weatherpack...
Continuing my Delphi GT search and wiring harness for my engine swap...the LS2/LS7 drive by wire throttle body is a GT connector as well, 6 pin...and it was harder to find Delphi part numbers for, so I figured I'd post them if anyone is curious (maybe it will help someone in a search some day).
The purple "secondary lock" or TPA is 15483798
The Grey "axial lock" or CPA is 15483798
The connector itself is 15355297...it includes the main inner connector seal
This uses the same pins/cable seals as the other stuff I posted already.
I'll probably keep adding to this thread as I dig up more part numbers for more wiring stuff I'll wind up needing for this swap.
D585 ignition coils:
Connector is 15439568
Cable holder/lock is 15305028
I also bought 2 more pin part numbers, 15326267 and 15326266, but I believe they're the same as the pins I mentioned in the injector post...they certainly appear to be the same in person.
