fuel injector issues i think... help!
I have bosch 36 lb injectors right now and i'm running so rich its crazy. like 10 mpg on avg. smokes bad between shifts, and my wide band almoost pegs out during pulls. the tune is set for 36# but its still way rich. i've been told these injectors are really hard to tune for... different rates or something? idk, locally i found a guy selling his 30# red tops fairly cheap. i wanna get these and i probably will tonight. but, i'm curious how will my car run since its tuned for 36# injectors. will i be okay for awhile? they will just plug and play correct?
how about get your tune right?
you may have something else wrong. I wouldn't go off and already be replacing your injectors when it probably isn't the problem. get your tuner to check **** like he should be doing
