Walbro GSS342 & Hobb's switch
Does anybody know for sure if the GSS342 from summit comes with the sock and wiring harness? Nobody at summit seems to know for sure.
Also I'm looking for a part number for a hobbs switch and the correct submersible hose. I need to add my second pump before I blow something up. Thanks!
That's what is in the car now as my 1st pump. The problem is I don't want to spent the extra 40 bucks if it isn't required. The pumps appear to be the same as far as flow. VPN-GCA758-2 is kit with stuff that I have in my garage already.
The GSS342 is just the pump, it will not come with the wiring or filter sock, thats why I said you want to get the kit. It will come with everything you need and isn't that much more expensive.
