collapsed braided return line
Old Sep 30, 2010 | 04:32 PM
LSXS15's Avatar
Default collapsed braided return line
went to start up my 6.0 swapped s10 and heard fuel hit the garage floor. i installed -6an jegs brand braided line and walbro 255 intank pump 2 weeks ago. the line is not kinked, overtightened, twisted or chaffing on anything. just looks like it collapsed on one side. again, this is the return line. did i just get a bad section of line or is there a ton of suction in the tank. also, the tank is half full and the vent tube is still in place. has anybody had a similar problem with this setup or line?
Old Sep 30, 2010 | 06:25 PM
venom99's Avatar
you got bad line
Old Oct 1, 2010 | 04:15 PM
LSXS15's Avatar
thats what i was hoping. thanks
Old Oct 1, 2010 | 06:51 PM
venom99's Avatar
i would use aeroquip hose though to be on the safe side it is a little more heavy duty
Old Oct 3, 2010 | 12:57 PM
LSXS15's Avatar
feed line just did the same thing, same place. travels behind the alternator and next to a coil. i dont know if it has to do with the placement or not. its just very strange. i ordered earls line the other day. hopefully this solves the problem
Old Oct 3, 2010 | 08:03 PM
venom99's Avatar
try to keep it away from that spot it may be geting hot in that spot and bending
