LS1 shut off while going 70mph
The thing is its getting pretty hard to start now lately i have to switch the ignition to ON then OFF for a 2 sec's and then crank after it gets coldish... any help guys?
maybe fuel pump or fuel filter?
But a failing Crank Shaft Position sensor will do that and act like that. Hard starts and it will shut your engine off at any time on you. Then it will run perfect......then it will act up again.
And you WILL NOT get an SES light/code until its 100% failed and you're stuck somewhere.
You could buy one and try it out, takes like 10 minutes to swap it out. Its under the starter. You drop the starter and there it is. If thats not the problem, clean it real good and return it for a refund. Just tell them it didn't fit because someone modded it and put a different one in there.....they will have no clue.
I'd also say dirty fuel filter can kill the engine.......but not if its ok at times, then its not.
