Anyone sell a fuel return setup
Also some instructions on how to plumb the fittings especially the top of the tank.
For example, for the 3/8" hard line, I used an Aeromotive 15118 (~$37 ea.), but you also have to buy another fitting to convert it back to standard -8AN (or -6AN if you so prefer), which is an Aeromotive 15607 (-8 straight cut o-ring boss to -8AN) at around $13 each. So ~$50 for each of those, and I have 4 in the back (two on top of the tank for feed/return, one going into the fuel filter, one coming off the EVAP hard line that I use as my return) and 2 up front (one for the 3/8" feed line, and one for the 5/16" EVAP). Then add in all of the other **** (like 90* couplers for clearance and all of the misc. fittings for aftermarket fuel rails), and it really adds up.
You can go a little cheaper on some of it, but if you go with the stainless braided line, you really need to use the PTFE stuff, and it isn't cheap to do. Plus I don't get to reuse any of my hose end fittings since the PTFE line takes a different style of fitting than the synthetic rubber braided line I originally used.
Not bitter or anything.
