What is everyone using to bend SS hard line?
Old Nov 2, 2010 | 07:15 PM
STEEPSS's Avatar
Default What is everyone using to bend SS hard line?
I've been searching around, and I can't find a straight answer.
I'm just curious what ppl are using to bend their stainless hard line. I'm doing a 5.3 conversion on my Datsun, and I'll be installing a new fuel system. I want to use stainless hard line, and stainless / Teflon lined flex stainless. This is so I can use it for E85 in the future, if I so choose.
I'll be buying a 37 degree flaring tool, and probably a bender. I was just hoping to find one for rent.
All line will be -6 AN fwiw.
Cheers
Old Nov 3, 2010 | 10:03 PM
David Q's Avatar
Tubing benders. Swedgelock makes a great roller set. You can pick up cheap used benders at the pawn shop. $15-30.
Old Nov 4, 2010 | 09:23 PM
STEEPSS's Avatar
Thanks.
Right now I'm in a bit of a dilema. I'd only have to make roughly 3 bends in the SS tube. So the added cost of the bender, plus the added fittings, and hassle, I'll likely just do SS braided, Teflon lined flex hose.
Old Nov 15, 2010 | 10:45 AM
sandeggo's Avatar
if you look at my first and only post, youll see some ss hardlines i did for fuel and water on my boat motor. if you use a swedgelok type fitting you dont have to flair the end of the tube. i used a parker bender for the bends.
if you only need to make a few bends, i would get a coat hanger and do the best bend template you could with it. take that to a parker-hannifan store near you and they'll bend it up for you
Old Nov 17, 2010 | 10:52 AM
STEEPSS's Avatar
I appreciate the reply, but I've decided I don't want the added headache of hard line. I'll just be running -6 TFE lined SS flex. Thanks!
