Racetronix. Little to no fuel pressure
Old 12-01-2010, 04:12 PM
candlelit's Avatar
Default Racetronix. Little to no fuel pressure
The shop just recently installed a fresh forged LQ4 motor and put a break in tune on it. I drove it around a bit yesterday and everything seemed fine. Ever since the car will crank but wont fire. I immediately thought of a bad crank sensor but when I checked my fuel pressure gauge and when I turn the key to the on position it only reads no more than 3psi. FP was fine driving around last night. Any ideas?
Old 12-01-2010, 04:14 PM
sway99bird's Avatar
Check Ur fuel filter see if its not clogged
Old 12-01-2010, 04:15 PM
sway99bird's Avatar
O and check Ur fuel lines above the tank headed to the filter make sure its not kinked from were they putty tank back in
Old 12-01-2010, 04:16 PM
sway99bird's Avatar
Put the *
Old 12-01-2010, 04:50 PM
candlelit's Avatar
You might be on a good path there. The car did sit for the last two years, but would a plugged up filter only allow nothing more than 3 psi?
Old 12-01-2010, 06:00 PM
PowerShift408's Avatar
Possibly a cut in the fuel line somewhere. I would change that filter to eliminate that problem and inspect the lines and I'd be pretty confident you'd find the issue in there somewhere.
Old 12-01-2010, 06:08 PM
three05s10's Avatar
i had the fuel line racetronix supplied me with split from the pump to hardline inside the tank. i had very little pressure, good luck.
Old 12-04-2010, 03:29 PM
candlelit's Avatar
ok so really no fuel pressure at all. I swapped fuel pump fuses and nothing. so either something is clogged up, something not getting electrical connection, or fuel pump gone bad. just changing the filter probably won't fix it... thinking I should get a little pressure if it were a clogged filter... anyone else agree?
Old 12-04-2010, 03:32 PM
candlelit's Avatar
oh one other thing... to test the fuel pump, I should be able to unhook the fuel filter from the fuel line and turn the ignition on and I should have fuel coming out if the fuel pump is working properly correct?
Old 12-05-2010, 09:20 PM
three05s10's Avatar
check the hose from the pump to the housing. i had good pressure one day, came out to fire the car up for a buddy the next day, itd fire up, but wouldnt rev. finally got to where itd bearly start. i pinched off the return line, still no psi, when i pulled the pump the rubber hose had ruptured.
Old 12-05-2010, 10:05 PM
candlelit's Avatar
k. figured I'll need to look into the fuel pump. but got to decide whether to drop a 98' tank or cut a hole. have to replace hatch shocks before I could get back there though. did racetronix supply you with another hose or will a gm replacement do?
Old 12-06-2010, 03:14 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
The Racetronix kit comes with the proper corrugated hose.
I would not use a kit with a rubber hose in the tank... they tend to be short lived.
Also the 98's tend to have some regulator issues, so check this out first before you start buying parts.
If interested, I'll be glad to set you up with a pump kit for your car.
Old 12-06-2010, 11:51 PM
candlelit's Avatar
ok thanks for the heads up, and I'll keep you in mind for parts. I bought a new filter tonight and I dropped the battery off to get charged (was showing ~9 volts in my car). hopefully the new filter or a properly charged battery will fix my problem, but we'll find out tomorrow evening...
Old 12-08-2010, 04:55 PM
candlelit's Avatar
update...
new fuel filter + charged battery = nothing. I still don't think my fuel pump is getting power (can't hear it running, all I hear is a "click" that comes from that direction, maybe its because all my other noises in the cabin when I turn the key over).
Old 12-19-2010, 12:50 AM
candlelit's Avatar
update...
My buddy and I cut a trap door tonight. Checked the voltage at the connector on top the fuel pump and got 5 volts with the key in run position. Noticed the plug states its a 5 volt connection? Odd, cause we were thinking it'd need 12v. Anyways, the pump wont turn on. So we pulled the fuel pump and couldnt figure out how to get that yellow plug looking deal from the harness on top out therefore I had to leave it in the car. Now what to do??? I'd hate to order a new pump if there's a way for it or something in the assembly causing the problem...
Old 12-19-2010, 09:34 AM
LS1TECH Sponsor
Should be 12v at the pump. You will only see voltage for a few seconds when you first key on.
Old 12-19-2010, 09:40 AM
bozzhawg's Avatar
Then it drops off to 2-4volts ? if so why....?
Bozz
Old 12-19-2010, 02:06 PM
candlelit's Avatar
oops, just realized that was the fuel tank pressure sensor we tested lol
Old 12-19-2010, 02:42 PM
candlelit's Avatar
Ok so I hear there is a place on the pcm that I can run a wire from it to the battery to get 12v to the fuel pump. Where is this connection thing or is it not on ls1 cars?
Old 12-19-2010, 05:26 PM
bigbirddriver94's Avatar
The fuel pump prime connector should be near the computer under the hood, im pretty sure its a gray wire. Is the pump hotwired?
Quick Reply: Racetronix. Little to no fuel pressure
